Re: Hot Water Heater Leak?
Posted by Bud..Suncoast Plumbing Inc. on November 04, 1998 at 17:43:00:
In response to Re: Hot Water Heater Leak?
Libby:-- Th eT&P valve is located either on top of the tank, or on the side but close to the top. It has a little toggle handle on it and is generally connected to a drain line running out doors. Your last post mentioned water running outside............could be your T&P drain line. Have a friend look at it for you....Bud
Replies to this post
There are none. |
