I am installing a Lasco 2pc shower unit in a bathroom with no access to bottom of shower after or during installation. It is old frame construction. What is the best drain for this situation. I'm not crazy about using a "no caulk" type drain and I'm not sure if I like the idea of using a standard solvent weld type (If it leaks after it's welded I'm in trouble). I like the looks of the Oatey 2pc with receptor. The Receptor is welded to 2in. pipe then shower base is installed and the top pc is screwed into receptor. How do these work??? They don't seem to be used much and do not seem to be readily available. Your help would be appreciated.
