| Posted by Libby on November 03, 1998 at 22:50:09: | |
| In response to Re: Hot Water Heater Leak? | |
: There is a constant hissing noise that seems to be coming form the hot water heater, which may be leaking. : The hissing noise only goes away when the outside main water supply is turned off. How do I tell if the leak is in the wall, the hot water heater, or somewhere else? I also noticed that the outside drain pipe drips a litte. Is this normal? : I appreciate you help. Thanks Bud, |
