Re: Kitchen Drain Pipe Leak
Posted by Paul on February 26, 19101 at 18:59:34:
In response to Re: Kitchen Drain Pipe Leak
first check that the washer ( tapered nylon ) is on properly, apply a little pipe dope onto the washer, and then a little onto the threads, tighten firmly, check for leaks. is the plastic nut cracked? is there a good washer where the disposer 'ell' connects to the disposer? Call your local plumber he/she needs work too.
Replies to this post
There are none.
