Can a dishwasher be connected to an island sink?
Posted by Chuck on February 26, 19101 at 13:46:42:
And is it legal to connect it below the kitchen floor to a seperate trap on the drain side of the UPC Island sink drain/vent instead of the tail piece? Everyone I talk to says that I should build the island vent/trap within the sinkbase cabinet. My personal choice would be to build a knee wall behind the cabinet and put it there. Any pro or cons would help. I personally don't want to look at my sloppy copper joints. Thanks in advance.
Replies to this post
- Re: Can a dishwasher be connected to an island sink? Paul 19:35:39 2/26/101(0)
- Re: Can a dishwasher be connected to an island sink? absolutly, I would suggest an island loop out of 2" pipe, and if you can build a knee wall that would be the place to put it, making sure that the drain is put in on the proper side of the loop. ( one side of the loop is a vent the other side is the drain ) install a garbage disposal and drain the dishwasher into that, or use a `y ` tail peice for the washer drain. sloppy copper joints are un-excusable. use a dry rag to whip off excess solder and flux only use enough solder to fill joint, Yes I know years of experence really help. enjoy p.s. I don't know the codes in your area but if I were the inspector a dishwasher drain under the floor would result in a RED tag Paul 19:08:36 2/26/101(0)
- Re: Can a dishwasher be connected to an island sink? absolutly, I would suggest an island loop out of 2" pipe, and if you can build a knee wall that would be the place to put it, making sure that the drain is put in on the proper side of the loop. ( one side of the loop is a vent the other side is the drain ) install a garbage disposal and drain the dishwasher into that, or use a `y ` tail peice for the washer drain. sloppy copper joints are un-excusable. use a dry rag to whip off excess solder and flux only use enough solder to fill joint, Yes I know years of experence really help. enjoy Paul 19:05:18 2/26/101(0)
