| Posted by david on February 26, 19101 at 12:55:22: | |
| In response to Re: American Standard Vent Away | |
First of all, let me say many thanks for your speedy follow up. This is absolutely amazing, and your reply is great!. One of the nuts is indeed a round nut with lots of holes in it (the Zurn carrier you mentioned?..its about the size and thickenessof a dollar coin). I'd aprpreciiate it if you could send me instructions for this. Once again, many thanks! : You put a nut on the two bottom bolts and the upper left one. You screw them on until they are flush with the tile. Then you put plain metal washer on each of the three so it sits on the face of the tile. Put the seal gasket in the bowl recess and mount the toilet using the cardboard washers and chrome acorn nuts. Finally install the fourth cardboard washer and acorn nut on the upper right bolt and just snug it against the bowl. This all assumes you do not have a Zurn carrier with a round nut with a lot of holes in it. If you have that then e-mail back for instructions for that nut.
| There are none. |
