Hot Water Heater Leak?
Posted by Libby on November 03, 1998 at 19:03:36:
There is a constant hissing noise that seems to be coming form the hot water heater, which may be leaking.
The hissing noise only goes away when the outside main water supply is turned off. How do I tell if the leak is in the wall, the hot water heater, or somewhere else? I also noticed that the outside drain pipe drips alittle. Is this normal?
I appreciate you help.
Replies to this post
