Re: Hot water line to ALL facuets
Posted by hj on February 24, 19101 at 14:22:31:
In response to Re: Hot water line to ALL facuets
You need to find a good plumber. One that does not say that, "The pressure simply had to build back up." The most recent one may also not be checking for the correct solution. Have a real plumber find out what the actual problem is before he starts changing things like the last one did.
: I had a slab leak in '97, when the contractor repaired the leak I noticed slight drop in the water preasure on the hot water line. I mentioned this and was told it simply had to build back up. Needless to say it never did. Approximately 1 month ago I started noticing a major decease of water flow coming from the hot water line to all facuets throughout my home. Hired a plumber, he replaced the pipes (cold & hot water lines), gate value, and replaced the union on the connection to the water heater. He also flushed the tank approx. 5 times. He stated the water pressure increased, however when I got home. . . it is nothing more than a trickle to all facuets. Now I'm told it cold be sediment buildup in the line. How is it detected where the buildup is and how is it repaired. Please help!
Replies to this post
There are none.
