| Posted by CM on February 23, 19101 at 17:54:37: | |
| In response to Re: Leaning toilet | |
Take a carpenter's level and check the floor in the vicinity of the toilet. If it is not level, call your contractor back and show him. If it is, the closet flange under the toilet may not have been installed flat to the floor. You can remove the toilet and shim it if the lean is not too great, but make sure you replace the wax ring with one that is thick enough to make up any difference in height from side to side.
| There are none. |
