Re: Detroit Home Inspector
Posted by Rod on February 21, 19101 at 09:16:32:
In response to Re: Detroit Home Inspector
Thank you, job completed and working well!
: Only if you cut the pvc with a saw. But this is easy to fix. Just a little pvc glue and a new section of pipe. Very easy to work with.
: : Thank you very much for your help. What if something happens and it needs to be taken off of the sewage drain can this be accomplished without damage?
: : : Not Terry but, yes! And screw it to the floor too. Make sure the slots in the flang are positioned so that you can set the toilet properly.
: : : I am not a plumber by trade. I renovate old homes, inspect old homes and renovated my share of bathrooms and kitchens.
: : : Good luck!
Replies to this post
There are none.
