| Posted by John Bridge on February 18, 19101 at 13:18:27: | |
| In response to Re: shower installation over toliet floor drain | |
: I would like to install a shower in a basement bathroom in which I am removing the toliet. Is there a shower pan available that includes a built-in trap so that I can easily connect the drain to the existing in-floor toliet drain? : If not, do I have any options short of building up the floor under the pan to install a typical trap arrangement? Hi Carl, No, you won't find anything that contains its own trap. The option would be to chop out the floor and install the trap. Then you can use any shower base you choose. John |
| There are none. |
