| Posted by hj on February 18, 19101 at 00:32:13: | |
| In response to Re: TUB DRAIN | |
Remove the piece of tubing from the pipe. Do not even think about silicone, epoxy, etc. inside the wall. : I'm trying to install a new bathtub in my upstairs bathroom. I brought a new overflow and drain unit. Everything was going well until i went to connect the tailpiece into the existing drain. Seems the old pipe wore out and snapped off inside, now i cant get the new tailpiece to seat into it.What would be the easiest way to connect the two? They are both brass. If i were to exchange the brass system with PVC,is it possible to connect the PVC into the brass fitting? Silicone,epoxy,etc? Thanks in advance for any advice........John
| There are none. |
