Re: OIL FURNACE WORKS FINE ..FOR THE FIRST CYCLE, THEN??????????????????
Posted by bryce cutis on February 17, 19101 at 15:04:03:
In response to Re: OIL FURNACE WORKS FINE ..FOR THE FIRST CYCLE, THEN??????????????????
: MY 20 YEAR OLD OIL FURNACE WORKS NORMALLY FOR THE FIRST CYCLE WITHOUT ANY PROBLEMS. AFTER THE FIRST CYCLE WHEN ROOM TEMP HAS SUFFICIENTLY DROPPED, FURNACE RESTARTS OK BUT NOW STARTS A BUZZING SOUND FROM A CONTROL BOX (HONEYWELL) RELAY. THEN WITHIN A MINUTE OR SO, BURNER SHUTS OFF. IF I HOLD THE RELAY CLOSED WITH MY FINGER, BURNER STAYS ON FOR REST OF CYCLE...IF I LET GO, BURNER KICKS OFF. IF I LEAVE IT ALONE AND THE ROOM TEMP DROPS WAY DOWN AND THE FURNACE IS ABSOLUTELY COLD, IT GOES BACK TO FIRST CYCLE STATUS AGAIN AND WORKS JUST FINE........WHAT SHOULD I LOOK FOR??????? BURNER IS EQUIPPED WITH EXCELLENT FILTRATION AND WATER SEPARATOR, FUEL SYSTEM HEATER TO PREVENT ICING, NEW NOZZLE, AND PROPERLY GAPPED ELECTRODES, AND BURNS CLEAN WITH PROPER DRAFT.
Replies to this post
There are none.
