| Posted by geoff on February 17, 19101 at 11:39:02: | |
| In response to Re: Replumbing of inslab copper. | |
: If you repair under slab or under ground make sure you check with the supplier and purchase the correct piping for this installation. In most areas building codes require a specific copper pipe type for this repair.
: You can attempt to pull new lines under the slab : You can break up the floor and make a repair on : You can repipe overhead with Copper,CPVC,HDPE or
| There are none. |
