| Posted by kate on February 16, 19101 at 13:41:08: | |
The faucet in my bathroom sink is corroded and the water does not flow correctly out of it (it flows toward the back of the sink). The sink is wall mounted and has a couple of dings in it and slightly corroded around the drain but okay. Does it make sense to replace the faucet and the sink at the same time (I will have to hire a plumber)? If I replace the sink, should I stick with a wall mounted or can a look into a pedestal sink without increasing the cost substantially? Any advice you could provide would be much appreciated. Thank you. |
| There are none. |
