Complete replumbing of old house, copper in, or under slab.
Posted by Carl on February 13, 19101 at 09:39:31:
I have a 2300 sft house on slab. The plumbing, I discovered when water started coming from the wall, is either under or in the slab. Replumbing into the attic is the only viable solution that I see. Would cpvc be the material to use? Even though I have installed toilets, sinks, drain systems in new construction, I'm not certain of the methods used to replumb. I'm so old that my experience is with the old iron pipe.
I'll probably have to contract the job out.
Replies to this post
