| Posted by Me again on February 11, 19101 at 15:13:47: | |
| In response to Re: Tub Spout Pipe - Water flows from it - HELP! | |
: The tub spout was dripping, then came the hot stream, then more or less like it was on low. I replaced the whole stem to the hot in tact, have made no adjustments to the stem assembly. : Still stream pours out of spout. Took off spout to reveil pipe sticking out off wll, the spout itself is not leaking - BUT the pipe is flowing freely. : What is the best thing for me to do at this point? Husband NOT a plumber of even amatuer nature so HELP! : My tub is a hot round on left and /cold round on right diverter /spout reg ol grade. : WHAT WOULD make spout pipe flow even when tub is off?? have a trap door to pipes opposite wall there are no pipe leaks on joint leaks. : Thank you so much for the help! PUTTING IN HOT OR COLD STEM |
| There are none. |
