Re: Moen Cartridges & Reduced Hot Water Flow
Posted by bob on February 10, 19101 at 09:55:08:
In response to Re: Moen Cartridges & Reduced Hot Water Flow
I've got the same problem with 4 different moen shower fixtures in the same building...I think this is a design problem at the built in shut off on the fixture...sediment seems to get stuck right there...There are no other pressure issues at any other fixtures in the building I wonder if this shut off is removable?...if you figure this one out, let me know...thanks and good luck
Replies to this post
There are none.
