Hot water radiator flush
Posted by Sean P Conely on February 09, 19101 at 14:07:47:
I have the old style hot water heaters and Want to flush the system or bled the system. I was told this might help them work more efficiently. I want to adjust the one radiator because the room is small and the room gets too hot. There is a big round adjusment valve but it is jammed and I am not sure wich way to turn it to adjust for less heat. I am thinking fo using a pipe wrench to get it to move but want to make sure I jam turning in the right direction. Thank you for all of your help and time.
Replies to this post
