Replacing toilet over rotted subfloor
Posted by Charmaine, reply by Bud...Suncoast Plumbing Inc. on November 01, 1998 at 12:47:41:
I'm repacing a toilet (the old one leaked). Found that the sub-floor was rotted & needs to be replaced. How do I remove the flange to put it on top of the new sub-floor? Charmaine Charmaine:--If it's a cast iron flange, you can very carefully drill out the lead caulking out of the joint, and simply remove. It may require a deep seal replacement closet flange if there is a considerable change in elevation. If its'plastic, cut it off flush with the floor,and use one that slips inside or over the pipe...Lots of luck with your project...Bud
Replies to this post
There are none. |
