| Posted by Suncoast Plumbing Inc. on February 08, 19101 at 20:35:57: | |
| In response to Re: broken sewage line | |
Ken: The terra cotta pipe can be cut easily with a skil saw with a masonry blade or if you have access to a pair of chain snaps that's even easier. Replace the clean out with a PVC one, and make the transition from clay pipe to PVC with a Fernco rubber coupling from the Home Depot. Lotsa luck ...Jose
| There are none. |
