| Posted by AALPHAWOLF on February 08, 19101 at 14:42:47: | |
| In response to replacing pipes | |
You might check your local plumbing codes first to see if plastic water pipe can be used. It never corrodes or contributes to a galvanic action, and is super easy to work with and quite inexpensive and doesn't require heat that could set things on fire. |
| There are none. |
