| Posted by AALPHAWOLF on February 08, 19101 at 02:47:40: | |
| In response to Re: Hole in Tub | |
SURE, A 2-PART EPOXY WILL WORK TO REPAIR THE RUST THRU. JUST BE SURE TO CLEAN ANY LOOSE RUST OR ENAMEL FROM THE SURFACE. ALSO TRY TO COAT THE 'OTHER' SIDE OF THE TUB WITH THE EPOXY. ONE COULD ALSO TRY THE EPOXY PUTTY THAT YOU ROLL TOGETHER, THEN PRESS IN PLACE. PROPERLY REPAIRED, IT COULD LAST INDEFINATELY. |
| There are none. |
