low water pressure?????????????????
Posted by AALPHAWOLF on February 08, 19101 at 02:20:14:
In response to low water pressure?????????????????
I SUSPECT THE PIPES HAVE A BLOCKAGE SOMEWHERE. THIS PROBLEM IS PROBABLY FROM DISTURBING THE PLUMBING. IT COULD BE CORROSION RELATED, OR A FOREIGN OBJECT. THIS MAY TAKE SOME DETECTIVE WORK TO DETERMINE THE MOST LIKELY LOCATION OF THE BLOCKAGE. THEN YOU MAY HAVE TO OPEN THE SYSTEM TO FLUSH IT OUT. COULD GET MESSY.
Replies to this post
There are none.
