| Posted by Pete Heckes on February 06, 19101 at 17:59:55: | |
My built in shower is leaking around the drain. I have poured water directly into the drain pipe, and eliminated it as the source of the leak. I confirmed that the leak is somewhere around the perimeter of the drain fitting itself. The shower base is a molded material. How can I replace the drain fitting to the drain pipe without tearing the entire base out? |
| There are none. |
