Re: Frozen Outbound or Sewage Pipe?? or Blockage??
Posted by Cheaper = Buy yourself a snake on February 04, 19101 at 17:19:36:
In response to Re: Frozen Outbound or Sewage Pipe?? or Blockage??
Buy yourself a snake from K-Mart or Wal-Mart to try to free the blockage.
: Hi, i'm having neat problems in my Trailer. I had a leaky faucet in the bathtub.. and then one night the water started collecting in the bathtub, didn't go down. The temperature had just gone down to -9 outside. After using the toilet, I flushed it, and IT didn't go down EITHER.
: So, faced with the leaky faucet (still going), i turned off the water to the trailer (only one shutoff valve).
: The next day the water level in the bathtub and the toilet dropped.. but when I tried to flush, or pour some water in the bathtub, it still stayed standing. Obviously, whatever drainage there was, wasn't much.
: I'm not really sure if this is a blockage, or a frozen pipe. One drainage company says: If it flows at all, even a little (like it did that first day) its probably not a frozen pipe. However, if it started suddenly, then its probably not a drain blockage. Its only affecting outbound, which is kinda wierd, but possible.. maybe the heattape around the output line is malfunctioning.
: Anyway, anticipating warmer temperatures tomorrow.. maybe a whole whopping 35! might be good enough to thaw stuff out.. If that doesn't do it, i'm thinking about calling RotoRooter. or a plumber. Whichever is cheaper.
: Any opinions/ideas would be greatly appreciated.
Replies to this post
There are none.
