| Posted by Steve on February 03, 19101 at 15:58:46: | |
I have a small basement with a sump pump. I want to install a bathroom and the location of the ejector pit will be near the sump pit. What is a good distance to keep between the two pits.? Also, I'm worried about breaking the exising drain lines going to the sump pump when I dig for the ejector pit. It seems that when I break through the cement I should still have several inches of dirt before I actually find the sump pump drain lines. Is this true? I can provide a picture of the area if needed. Thank You! Steve Sluder |
| There are none. |
