Posted by Tony, reply by hj on November 01, 1998 at 10:43:05:
Spray nozzle from my moen kichen faucet has very little presure. I understand there is a so-called diverter, which may be the source of my problem. How can I correct this and how do I get to it. This is a new unit, so since the house is new as well, probably some sand may have gotten in the line causing it to clog. Your help would be appreicated.
If the spray is separate then the diverter is in the center section under the spout. If it is a pull out spout, then the check valve wher the hose connects under the sink may be plugged or the aerator can be obstructed.
Replies to this post
There are none.
