My flooring was ruined recently when a toilet leak flooded our entire house. This occured because my house is on a slab, so the water ran through all the walls and pretty much totaled my floors. If the the leak could have been detetected the minute the bathroom floor became wet and an electrically controlled valve connected to the supply line would have shut off the supply line this disaster could have been prevented. I know this is possible. Is this system available to connect to the supply lines of toilets. I know it is possible to rig up the leak detector all you have to do is trigger it with the continuity of the water. But is the electrically controlled valve available? HELP. THANKS RICK
