| Posted by MARTY on January 30, 19101 at 12:41:59: | |
| In response to Re: Pressure Testing Drain Lines | |
: What are the best ways to pressure test drain lines? : Would this method be appropriate? Placing a test plug (like a baloon)in the clean out, making sure all drain stub outs are plugged, filling up the vent lines from the roof with water, and then check for leaks. Will this method generate too much water pressure? : that is the correct way to test |
