| Posted by CM on January 30, 19101 at 12:05:05: | |
| In response to Re: Thanks, more questions.... | |
: : : Your county (or other municipality) is the final arbiter of what codes to use and how to interpret them. This means that if the local guy decides that you have to paint your piping green with red stripes to satisfy a code requirement, you gotta do it. : Okay, but how about if the county code doesn't mention hot water heater pan required under the hot water heater but the state code does and the county plumbing inspectors don't inforce the state code. Does that mean that plumbers who install replacement hotwater heaters don't have to mention to the homeowners the need for the pans? In other words, do the county plumbers not have to comply with the state codes?. If the county code references the state code (and it probably does) and does not specifically exclude the need for the pans, they are required whether the county chooses to enforce the requirement or not. Therefore, it would be incumbent on the plumber to install the heater per code, i.e. with a drain pan, if the county adopts the state code without an exception. Note that in the National Standard Plumbing Code, this pan is NOT required when the floor is a slab on grade and not subject to water damage (i.e. made of concrete). |
