| Posted by Deron on January 30, 19101 at 11:43:21: | |
What are the best ways to pressure test drain lines? Would this method be appropriate? Placing a test plug (like a baloon)in the clean out, making sure all drain stub outs are plugged, filling up the vent lines from the roof with water, and then check for leaks. Will this method generate too much water pressure?
