| Posted by Margie on January 26, 19101 at 13:11:09: | |
If a hot water pipe crosses over a cold water pipe, and the two pipes are touching each other at the point where they cross, does that create a problem? If so, what should be done about it? In case it makes a difference, the cold water pipe is an older steel pipe, while the hot water pipe is a new copper pipe, and this is in a single family home. |
