Re: Can I glue Wonderboard to an old plaster wall?
Posted by chopper on January 26, 19101 at 13:01:54:
In response to Re: Can I glue Wonderboard to an old plaster wall?
You can, but it is not advisable because the wonderboard can hold moisture successfully, but the plaster cannot. The right way is to remove the plaster, put up a vapor barrier, and nail the cement board to the studs. If you absolutely need to leave up the plaster board, go with a waterproof glue to apply the wonderboard, Not thinset.
Replies to this post
There are none. |
