| Posted by hj on January 26, 19101 at 08:57:51: | |
| In response to Re: Gas water heater goes out during high use. | |
I would suspect poor ventilation rather than excessive fresh air. The condition you describe will occur if you have poor ventilation or a plugged flue so carbon monoxide builds up in the heater room and eventually extinguishes the flames, shutting down the safety pilot. Install a CO detector in the room and see if it activates. Any home, (especially mobile homes), with a gas burning appliance in it should have CO detects as a standard item. : I have a manufactured home with a 40 gal. gas water heater. During or after high use I find the pilot out. When I re-light it there is water condensation in the burner orifices.As it begins to heat up, a lot of condensation will drip from in the flue-stack. Could this be because it is pulling air very cold moist air from outside and condensing it in the flue? I have ruled out a leaky tank. The problem just started this winter. A cover that protected the opening under the house is missing since summer and allows air from outside to enter the combustion air vent directly.
| There are none. |
