| Posted by hj on January 25, 19101 at 00:26:42: | |
| In response to Re: Standard supply pipe ID | |
3/4" copper is the norm. 3/4" CPVC plastic has the same opening as 1/2" copper. And 1/2" plastic, if it is CPVC has a 3/8" opening which is too small for any use except a single fixture. If you used regular PVC piping, then you have a bigger problem than just undersized piping. : Can you tell me what the standard supply pipe size is? : A few years ago I took all of my galvanized pipe out and replaced it with 1/2 inch plastic. When you take a shower, and someone starts the washer it really affects your water temperature. Some tell me that 3/4 is the norm. Thank You.
| There are none. |
