Re: Water Leaks in Foundation
Posted by CM on January 22, 19101 at 21:19:21:
In response to Re: Water Leaks in Foundation
Not many cons - but the garage should be heated or you will need to heat trace the lines. Make sure that the pipes are on the warm side of the insulation. I'm assuming of course that you don't live in the Carribean...
The other note is to make the most of this and any opportunity to upgrade the system, i.e. adding isolation and drain valves and shock absorbers to the piping. The absorbers are particularly important for washing machine feeds as they have quick closing valves that tend to promote water hammer.
: I live in a house on a slab foundation. A leak has developed in the form of seepage coming out of the
: garage (concrete) floor very close to where the washing machine is. My question is what are the
: pro's and con's of rerunning the hot water pipes through the attic instead of tearing into the foundation to
: repair the leak.
Replies to this post
There are none.
