| Posted by hj on October 30, 1998 at 09:17:32: | |
| In response to Re: Toilet Flange Installation | |
The wax ring sets on the flange and fills the space between it and the toilet. The system was designed so that a flange can be a little ways above the floor and there will still be adequate sealing with the wax ring. Dry fit and shim the toilet before installing it with the wax ring, because it will not seal properly if the toilet is lifted after the initial seal is made. You must glue it, and you should also screw it down but that is not always done unless the pipe is not rigid. : I have cut my 3" PVC drain line flush with the finished floor and will be installing the toilet flange. I have a few questions:
| There are none. |
