| Posted by CM on January 22, 19101 at 14:10:41: | |
| In response to Re: wall toilet | |
Maybe not be so simple - the waste line may run horizontally through the wall before it goes under the slab. Not likely, but something to check before you rip up the slab. : You can break into the floor and install conventional toilets. It is not an extremely expensive operation, although you also have to open the wall and remove the toilet hanger fitting for the wall hung. : : home we bought several months ago has a wall mount toilet, is there anyway when we remodel to put a conventinal toilet in, or willit have to be a wall toilet?
| There are none. |
