| Posted by dick on January 22, 19101 at 02:12:14: | |
| In response to Re: venting a bathroom fan | |
No! not a good idea to vent a bath fan into a crawl space. It could cause moisture accumulation problems. but, there is no reason you can't just run the pipe thru the crawl space to an exterior wall. use rigid metal pipe to cut down on drag. you might need a larger than normal fan to get enough air flow. (I'm not sure why you would have problem with sewer gas in a bath vent fan unless you do some really "creative" plumbing!) : Want to install a bathroom in our Victorian home built
| There are none. |
