Re: plumbing drain lines
Posted by hj on January 21, 19101 at 17:23:31:
In response to Re: plumbing drain lines
No, any layout will not be okay. The system that would be required, if you had codes and inspections, is the one that will give you the least problems over the life of the system. Install a proper drain and vent system even if you do not have to. It may cost a little bit more at first, but you will save money in the long run.
: Terry
: This summer Iam going to be building a new house I need a drawing on how to install the waste lines. The home will be in the county there is no building codes, so any layout will be ok. Any help?
: Thank You
: Paul Townsend
Replies to this post
There are none.
