| Posted by B. Norbert on January 20, 19101 at 22:49:45: | |
| In response to Re: garbage disposal turns but double sink filling with water | |
You definitely have drain pipe that is beginning to plug up. Snaking it out will solve your problem. : I have a double sink in my kitchen. When I use the side that is attached to the disposal, water backs up on both sides of the sink. I have to turn on the disposal and eventually the water clears out of both sides. The disposal is turning and it does grind up : thanks,
| There are none. |
