Re: water hammer
Posted by B. Norbert on January 20, 19101 at 22:39:36:
In response to Re: water hammer
This noise is caused by a loose washer, perhaps in the ballcock of the toilet or another valve somewhere in the house. Most likely it's the toilet in need of a rebuild.
Hope it helps.
: : I have lived in this house for 10 years and all of sudden this year I get water hammer. It is getting louder and louder. Question, how do you get the air out of the lines. When I turn on the tap it stops only to return again whenever I use a tap or flush a toilet. My house is heated with ground source heat. Not sure if that would cause it.
Replies to this post
There are none.
