Re: Plumber's Putty Instead of Pipe Joint Compound
Posted by george on January 20, 19101 at 15:44:19:
In response to Re: Plumber's Putty Instead of Pipe Joint Compound
: Could the plumber's putty be used to seal threaded brass connections for cold water supply line, instead of using the pipe joint compound or Teflon tape? If not, what implications would this have down the road if done?
According to the book "Plumbing a house" by Peter Hemp, you should wrap the male piece with teflon tape and put plumber's dope on the threads of the female piece. He says it really lowers the chance of a leak.
Replies to this post
There are none.
