| Posted by David Duncan on January 19, 19101 at 21:23:53: | |
| In response to Re: finding toilet for nonstandard rough-in | |
Thanks. That may be the only solution available, though it would require knocking a new hole in the floor. I know the European toilets fit because they have a much, much shorter rough-in distance (which is what I was measuring--the distance from the wall behind the toilet to the center of the waste pipe hole into which the toilet drains). : I'm not sure what you're measuring, but if the actual hole in the floor and pipe are that close to the back wall, perhaps you could use a floor mounted, rear exit toilet that would then ell down into the floor drain. Several manufacturers make these, including American Standard. :
| There are none. |
