Re: finding toilet for nonstandard rough-in
Posted by Charlie on January 19, 19101 at 10:45:19:
In response to Re: finding toilet for nonstandard rough-in
I'm not sure what you're measuring, but if the actual hole in the floor and pipe are that close to the back wall, perhaps you could use a floor mounted, rear exit toilet that would then ell down into the floor drain. Several manufacturers make these, including American Standard. : I have an Ifo toilet in my house with about a 2 1/2 inch rough-in. I can't find these toilets anymore, and my : father-in-law has great need of one, because a contractor error in his basement has left him with a rough-in : too close to the wall of his unfinished bathroom to use a standard U.S. toilet (about 5" from studs to center : of rough-in hole). Does any other manufacturer import toilets with European rough-in dimensions into the U.S.? : Is there any other solution?
