Re: toilet flange too high after new tile floor
Posted by CM on January 18, 19101 at 13:17:07:
In response to Re: toilet flange too high after new tile floor
I had a similar situation. I would strongly advise against shims/caulk bead, you want the water closet to be absolutely stable to avoid leaks at the wax seal and/or seasickness when you are using it. My solution ultimately was to cut off the PVC pipe below the old flange (using a Dremel tool with a cutoff wheel working around the inside of the pipe) and adding the new flange with a new coupling. It was a nasty little project but well worth the trouble. Good Luck! CM
: Terry what a great site!
: My flange site sits too high now that new floor is in. The toilet needs plastic shims to sit correctly. Should I leave it as is or should a plumber reset flange which is PVC pipe. I had an old tile floor before which I guess was higher.
: I was also thinking of a nice silicone caulk bead aound underside of toilet, allowing it to set up for a while then replacing toilet over flange may help.
: thanks in advance!
Replies to this post
