| Posted by hj on January 17, 19101 at 00:49:15: | |
| In response to Re: Dual Shower Heads | |
Probably none of the above. Just treat each one as a normal fixture without any consideration of the other one. The new valves should be pressure balanced and the shower heads will have flow limiters so they should not conflict. : I'm replacing a old shower/tub combination with an oversized fiberglass enclosure and installing two complete shower fixtures....one on each side....do I need to change the supply line size to keep the pressure up, increase my water pressure on my pump or do I just need to make sure I have it plummed in a parallel fashion?
| There are none. |
