| Posted by Scott on January 16, 19101 at 10:00:28: | |
| In response to Re: Kohler Rialto - silent leak | |
: Rialto was installed in 1990. Put food coloring in tank to test for "silent leak" as per condo instructions. Red water appeared in bowl. What needs to be done??? Many thanks. Sue, you need to replace the flapper. be sure to use the original kohler part and that should solve your problem. Here is a link to the parts breakdown on the Rialto toilet. Scott |
| There are none. |
