| Posted by Marty on January 15, 19101 at 23:01:37: | |
| In response to Re: emergency pan for under washer | |
I've never seen a waterpan large enough for a washer or dryer. However, you could try a sheet metal company. Give them the dimensions you want the pan built and I'm sure they can help you. You'll need to drill a hole in the side or bottom of the pan to accomodate a fitting so that a pipe or hose could be attached to.Marty |
